Введение
The paper tray is what feeds paper to the printer. If the paper tray is malfunctioning, the HP OfficeJet 4650's printing function will not work. This guide will show you how to replace the paper tray.
Выберете то, что вам нужно
Use two hands to carefully flip the printer upside down.
Remove the ten 14mm screws by using a 2.0 mm hex screwdriver and turning the screws counterclockwise.
Remove the left spring by grabbing the rubber tips connected to the spring and lifting up.
Remove the right spring by grabbing the rubber tips connected to the spring and lifting up.
Еще один человек закончил это руководство.
3 Комментариев
Any ideas where a aperson could order a replacement paper tray like this one? (For an HP OfficeJet 4650 model?
