Введение
The paper tray is what feeds paper to the printer. If the paper tray is malfunctioning, the HP OfficeJet 4650's printing function will not work. This guide will show you how to replace the paper tray.
Запчасти
No parts specified.
  1. Use two hands to carefully flip the printer upside down. Remove the ten 14mm screws by using a 2.0 mm hex screwdriver and turning the screws counterclockwise.
    • Use two hands to carefully flip the printer upside down.
    • Remove the ten 14mm screws by using a 2.0 mm hex screwdriver and turning the screws counterclockwise.
  2. Lift the left and right side flaps away from the paper tray to remove them. Lift the left and right side flaps away from the paper tray to remove them.
    • Lift the left and right side flaps away from the paper tray to remove them.
  3. Remove the left spring by grabbing the rubber tips connected to the spring and lifting up. Remove the left spring by grabbing the rubber tips connected to the spring and lifting up. Remove the left spring by grabbing the rubber tips connected to the spring and lifting up.
    • Remove the left spring by grabbing the rubber tips connected to the spring and lifting up.
  4. Remove the right spring by grabbing the rubber tips connected to the spring and lifting up. Remove the right spring by grabbing the rubber tips connected to the spring and lifting up.
    • Remove the right spring by grabbing the rubber tips connected to the spring and lifting up.
  5. Remove the paper tray by pulling the tray away from the printer.
    • Remove the paper tray by pulling the tray away from the printer.
Заключение
Stephanie Carpintero
Участник с: 24.01.2018
943 Репутация
Автор 5 руководств
Команда
Cal Poly, Team S19-G6, Livingston Winter 2018 Member of Cal Poly, Team S19-G6, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G6
3 членов
Автор 5 руководств
Добавить комментарий
Просмотр статистики:
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 51
За всё время: 1,034
