Введение
If your device will not fax, one possible solution is to replace the fax feeder. The fax feeder is necessary for sending more than one page of a fax at a time, and if it is malfuctioning, the printer may not fax at all.
Выберете то, что вам нужно
Use the plastic opening tool to pry the pivot point apart while lifting the feeder up.
Use a screwdriver to remove the single 9mm T10 screw.
Remove the wire cover and pull the wire away from the printer. The fax feeder head is now free to be separated from the printer.
2 участников успешно повторили данное руководство.
Один комментарий
I am so glad i found this site…I was able to unjam a lease that had gotten stuck…..thank you thank you7… times over…Lee
