Введение
This guide will show you how to remove the LCD display.
Запчасти
Никакие детали не требуются.
  1. There is a hidden screw underneath the model sticker on the front panel.
    • There is a hidden screw underneath the model sticker on the front panel.
    • Peel the model sticker off the cover.
    • This will expose the T10 screw securing the panel.
  2. Remove the single 12mm-T10 screw securing the front panel to the printer body.
    • Remove the single 12mm-T10 screw securing the front panel to the printer body.
    • Loosen the panel cover from the printer body.
    • There is a ribbon cable connected to the backside of the cover. Disconnect the cable before separating the panel completely.
    • Gently remove the No-Fuss ribbon cable from the front panel.
    • Remove the seven 8mm screws using the Torx T6 screwdriver.
    • Remove the motherboard from the front-panel housing.
    • The LCD display is on the opposite side.
Заключение
Justin Engwall
Участник с: 23.01.2018
116 Репутация
1 Guide authored
Команда
Cal Poly, Team S18-G3, Livingston Winter 2018 Member of Cal Poly, Team S18-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G3
4 членов
Автор 7 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 4
За 30 дней: 23
За всё время: 205
