Введение
This guide will show you how to remove the LCD display.
Выберете то, что вам нужно
Peel the model sticker off the cover.
This will expose the T10 screw securing the panel.
Remove the single 12mm-T10 screw securing the front panel to the printer body.
Loosen the panel cover from the printer body.
Remove the seven 8mm screws using the Torx T6 screwdriver.
Remove the motherboard from the front-panel housing.
Еще один человек закончил это руководство.
