Введение
This guide will show you how to replace the power supply in your HP Officejet 4630. The power supply is easy to replace and can be done with only a screwdriver.
Запчасти
Никакие детали не требуются.
  1. Lift the hood of the printer.
    • Lift the hood of the printer.
  2. Remove the two T10 11mm screws.
    • Remove the two T10 11mm screws.
    • Remove the panels covering the power brick and cord.
    • Remove the cord from the power supply.
    • Slide the power supply out from the chassis.
    • The power supply is still attached; don't pull too quickly.
    • Remove final cable from power supply.
Заключение
2 участников успешно повторили данное руководство.
Maya Willis
Участник с: 24.01.2018
343 Репутация
Автор 3 руководств
Команда
Cal Poly, Team S18-G3, Livingston Winter 2018 Member of Cal Poly, Team S18-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G3
4 членов
Автор 7 руководств
Один комментарий
Would like to know a reliable source for the
A9T80-80006 power adapter that does not cost 1/3 rd the price of a new printer
Mark Stephen - Ответить
Просмотр статистики:
За 24 часа: 6
За 7 дней: 34
За 30 дней: 189
За всё время: 1,057
