Введение
The speaker in your printer could wear out and stop working. This guide will show how to replace the speaker if it stops working. This process will require soldering skills because unplugging the speaker from the control board is a very difficult process.
Выберете то, что вам нужно
Peel the model sticker off the cover.
This will expose the T10 screw securing the panel.
Remove the single 12mm-T10 screw securing the front panel to the printer body.
Loosen the panel cover from the printer body.
Remove the seven 8mm screws using the Torx T6 screwdriver.
Remove the motherboard from the front-panel housing.
Remove the clip that keeps the printer lid from opening all the way with your hands by pulling away from the post on the lid.
Remove the paper feed rollers by using your fingers to pinch the indentations together while pulling up.
Push the clip holding the speaker in away from the speaker while pulling up on the speaker.
At this point you must cut and solder on your new speaker.
