Введение
Are the buttons not working on your printer? Consider using this guide to replace the buttons in your device.
Запчасти
No parts specified.
  1. Insert 2 fingers in the dent on the right side of the printer and pull towards the front of the printer. Using fingers to open the cover of the scanner which located on the top of the printer.
    • Insert 2 fingers in the dent on the right side of the printer and pull towards the front of the printer.
    • Using fingers to open the cover of the scanner which located on the top of the printer.
  2. Remove four 10mm screws on the panel with T8 torx security screwdriver. Remove the cover of the top part. Remove the cover of the top part.
    • Remove four 10mm screws on the panel with T8 torx security screwdriver.
    • Remove the cover of the top part.
  3. Remove eight 10mm screws on the back of the controlling keyboard with T8 torx security screwdriver. Remove the back board of the controlling keyboard. Remove the back board of the controlling keyboard.
    • Remove eight 10mm screws on the back of the controlling keyboard with T8 torx security screwdriver.
    • Remove the back board of the controlling keyboard.
  4. Remove the button that is located at the left of the controlling keyboard. Remove the button that is located at the left of the controlling keyboard. Remove the button that is located at the left of the controlling keyboard.
    • Remove the button that is located at the left of the controlling keyboard.
Заключение
Jiayin Zhu
Участник с: 21.10.2018
349 Репутация
Автор 3 руководств
Команда
UC Davis, Team S11-G8, Lore Fall 2018 Member of UC Davis, Team S11-G8, Lore Fall 2018
UCD-LORE-F18S11G8
3 членов
Автор 4 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 1
За всё время: 54
