Введение
The sensor chip is a small, green chip located in the top-right corner inside printer. It is held in by a small screw.
Выберете то, что вам нужно
Open the main lid as far as it will go.
Use a plastic opening tool to gently pry off the hinge on the right side by pushing it to the left and off the hook.
Open the lid further.
Use a T9 torx screwdriver to remove a total of ten (10) 12mm screws from the main cover by turning the screwdriver counterclockwise.
Grab the base of the white ribbon cable connecting the cover to the base of the printer and pull it out.
Twist the screwdriver counter-clockwise to remove the T9 screw on the sensor chip.
Pick up the sensor chip by the edges.
Pull the white cable to disconnect it from the sensor chip.
Repeat the process with the cable on the bottom.
Еще один человек закончил это руководство.
