Введение
The CMOS battery is an on-board memory storage battery. If you're HP Officejet Pro 8625 is losing data frequently or shutting off randomly, you may need to replace the CMOS battery. Removing the CMOS battery will reset all settings to default.
Запчасти
Никакие детали не требуются.
  1. Remove the two 11.6 mm T9 screws from the right side of the back of the printer. Remove the two 11.6 mm T9 screws from the right side of the back of the printer. Remove the two 11.6 mm T9 screws from the right side of the back of the printer.
    • Remove the two 11.6 mm T9 screws from the right side of the back of the printer.
  2. Pull down the front panel to expose the screws on the front. Remove the one 11.6 mm T9 screw on the left side of the front face. Remove the one 11.6 mm T9 screw on the left side of the front face.
    • Pull down the front panel to expose the screws on the front.
    • Remove the one 11.6 mm T9 screw on the left side of the front face.
  3. Remove the side panel by pushing down and towards the back. This step may be easier if the printer is laid on its side with the left side panel facing up.
    • Remove the side panel by pushing down and towards the back.
    • This step may be easier if the printer is laid on its side with the left side panel facing up.
  4. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  5. Remove the three 5.3 mm T9 screws from the motherboard. Remove the one 6.7 mm T9 screw from the motherboard. Remove the one 6.7 mm T9 screw from the motherboard.
    • Remove the three 5.3 mm T9 screws from the motherboard.
    • Remove the one 6.7 mm T9 screw from the motherboard.
  6. Remove the connectors from the front and sides of the motherboard by pulling straight away from the connection. Remove the connectors from the front and sides of the motherboard by pulling straight away from the connection.
    • Remove the connectors from the front and sides of the motherboard by pulling straight away from the connection.
  7. Lift the bottom of the motherboard and remove the connectors from the back. Remove the motherboard. There are two white connectors underneath the motherboard, remove them separately.
    • Lift the bottom of the motherboard and remove the connectors from the back.
    • Remove the motherboard.
    • There are two white connectors underneath the motherboard, remove them separately.
  8. Locate the CMOS battery on the motherboard. Remove the CMOS battery by pinching the top and pulling away from the motherboard. Remove the CMOS battery by pinching the top and pulling away from the motherboard.
    • Locate the CMOS battery on the motherboard.
    • Remove the CMOS battery by pinching the top and pulling away from the motherboard.
Заключение
Cam Engle
Участник с: 08.10.2018
387 Репутация
Автор 3 руководств
Команда
Cal Poly, Team S13-G3, White Fall 2018 Member of Cal Poly, Team S13-G3, White Fall 2018
CPSU-WHITE-F18S13G3
3 членов
Автор 7 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 9
За всё время: 63
