Введение
Use this guide to replace the keyboard in a HP Omen 15-5002xx. The keyboard is the main way to enter information into your computer.
Выберете то, что вам нужно
Flip the laptop upside down so the backside is facing up.
Use a spudger or your fingers to remove the thin rubber strips that are attached from the edges of the laptop.
Unscrew all 14 screw with the J00 JIS Screwdriver.
Open the case slowly from opposite sides of the laptop.
Use the J00 JIS screwdriver to remove eight screws securing the battery.
Carefully remove the battery connector that is attached to the motherboard by slowly sliding it towards the battery with two fingers.
Remove the battery by lifting it up and out.
Инструмент, используемый на этом этапе:Flathead 1.5 mm Screwdriver$5.49
Remove the twelve big screws with the J00 JIS screwdriver.
Remove all eight small screws with the 1.5 flathead screwdriver.
Carefully detach the fan connector that is attached to the motherboard by slowly sliding the connector out with two fingers.
Remove the battery carefully.
Carefully remove the Wi-Fi Card by slowly sliding the card sideways away from the motherboard.
Use the 1.5 flathead screwdriver and remove the twelve screws from the motherboard.
Disconnect the remaining four connectors from the motherboard.
Remove the motherboard.
Remove all 51 screws using the 1.5 mm flathead screwdriver from the underside of the keyboard.
