Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Does your hard-drive not have enough stroage and you want to swap it for a larger storage hard-drive? Well, reading this guide will show how. To disassembly the hard-drive on this computer, it is very easy and will only take about 5 minutes. This guide includes the pre-requeste of removing the back cover and the battery. Once you the back cover and the battery, removing the hard-drive is as easy as flip, pull, lift. The tools that you will need are one, a Philips #00 screw driver and two, a blue plastic opening tool.
Выберете то, что вам нужно
The rear panel is secured by 10 screws. Using a #00 Phillips Screwdriver, remove the ten 1.2 mm screws.
The screwdriver should be inserted at the same angle as the screws.
Insert a plastic opening tool between the rear panel and the top case. Pry the opening tool upwards to separate the top case from the bottom case.
Slide the opening tool along the case perimeter to loosen the bottom case.
Gently pull the bottom case away from the laptop.
Pull the battery cable out from its motherboard socket.
Remove the battery.
Disconnect the power cord from the battery and transfer it to your replacement battery.
After the battery is removed, the hard drive will be easier to access in the top right hand corner.
With a opening tool, flip open the switch that locks in the hard drive ribbon cable into the device.
Remove the rubber guards on the side of the hard drive.
Gently pull the plastic connector out from the hard drive.
The hard drive can now be disposed of if needed.
3 участников успешно повторили данное руководство.
