Введение
This guide will instruct a user on how to remove the fan in order to replace a potentially faulty piece of hardware. Be sure the device is turned off and disconnected from all power sources.
Выберете то, что вам нужно
Use the nylon spudger to remove the rubber pads near the hinge of the screen, then remove the screws under the pads.
Use the Phillips #0 to remove four 9mm screws.
Use the Phillips #0 to remove seven 6mm screws.
Use the nylon spudger to pry the back casing near the hinges for the screen.
Continue to pry along the edge of the back case until the back is ready to be removed.
Use the blue plastic opening tool to lift up on the white tab that is holding the cable in place on the motherboard.
Now carefully pull the cable out of place and remove the entire back casing.
Remove the five 6mm screws that hold the battery in place using the Phillips #0.
Use the nylon spudger to pry away the blue/white wire that is positioned near your battery.
Disconnect the battery cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
Use the plastic opening tool to slowly loosen the connection cable.
Once the connector is loose enough, grab the cable and carefully pull it free from your device.
2 участников успешно повторили данное руководство.
