Введение
This guide will be used for almost every other replacement guide for the HP Pavilion 13-s128nr. This is because this guide is used for opening up the HP Pavilion 13-s128nr to get to the interior parts.
Выберете то, что вам нужно
Use the iFixit opening tool to take off the rubber caps.
Remove the screws using the Phillips #0 screwdriver.
Use the Jimmy to pry around the seam of the laptop.
Remove the back panel of the laptop.
Using the iFixit opening tool to lift the tabs holding in the cables connecting the keyboard to the motherboard.
Pull the cable from the motherboard.
