Выберете то, что вам нужно
Use the iFixit opening tool to take off the rubber caps.
Remove the screws using the Phillips #0 screwdriver.
Use the Jimmy to pry around the seam of the laptop.
Remove the back panel of the laptop.
Using the iFixit opening tool to lift the tabs holding in the cables connecting the keyboard to the motherboard.
Pull the cable from the motherboard.
Lift upwards on the black tabs the purple strip is connected to.
Gently pull the purple strip out of its place.
Using the Phillips #0 screwdriver, remove the five screws holding the battery in place.
Pull the white cable connected to the motherboard out using the iFixit opening tool.
Look on previous instruction for how to open the laptop!
Remove these cables
