Введение
This guide will teach you how to remove and attach the battery in the HP Pavilion 14-bk061st. The battery supplies the power to the device even when the charger is not attached. Batteries are usually rechargeable.
As a note before starting this guide: check the battery for any defects as it can overheat and start an explosion if it is damaged. Check the troubleshooting page to see if the issue can be solved without having to open up the computer.
Remember to power off the computer, as well as disconnect all external components that are plugged into it.
Выберете то, что вам нужно
Remove the three 5.7 JIS #1 screws from the bottom of the laptop.
Remove the two 6.7mm JIS #1 screws from underneath the feet of the laptop close to the exhaust vent.
Unclip the back plate using a plastic opening tool.
https://www.youtube.com/watch?v=xXhVP0Un... This video helped a little. It is very hard to pry the left or right side away as the manual says. The video shows lifting from the center of the back. This bows the lid and consequently pulls the left and right sides inward slightly. I enhanced this movement by pushing inward from the right and left sides with my thumb while pulling up from the center of the back panel. This popped open the clasps on the right. Lifting the right back corner and pulling to the right, I got the clasps on the left to disengage. Once the clasps on the left and right towards the back came loose, the rest was far less stubborn.
Lift the battery up and away from the battery pins.
4 участников успешно повторили данное руководство.
2 Комментариев
I can’t remove the backplate because I can’t find the clips. How do I get the backplate off after unscrewing the screws? (I am using an ifixit pro tech toolkit.)
We were able to get the backplate unclipped by starting between the hinges and sliding the tool along until the opposite end. Then we went back to the hinges and worked our way around in the opposite direction and the plate came right off without any fuss.
