Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
Using this guide, you can replace the motherboard in your HP Pavilion 14-bk061st laptop.
The motherboard is the central connection between all the components of a computer. A faulty motherboard can lead to the whole computer failing so it is important to keep good care of all the components in your PC.
  1. Remove the three 5.7 JIS #1 screws from the bottom of the laptop. Remove the two 6.7mm JIS #1 screws from underneath the feet of the laptop close to the exhaust vent.
    • Remove the three 5.7 JIS #1 screws from the bottom of the laptop.
    • Remove the two 6.7mm JIS #1 screws from underneath the feet of the laptop close to the exhaust vent.
  2. Unclip the back plate using a plastic opening tool.
    • Unclip the back plate using a plastic opening tool.
  3. Carefully remove the back plate from the laptop.
    • Carefully remove the back plate from the laptop.
  4. Use the hook end of the Halberd spudger to pull back the clamps holding the card in place.
    • Use the hook end of the Halberd spudger to pull back the clamps holding the card in place.
    • Take care when pulling the second clamp as the card has a tendency to jump out.
  5. Remove the card by pulling it up and away from the slot.
    • Remove the card by pulling it up and away from the slot.
  6. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Купить сейчас
    Купить сейчас
  7. Disconnect the two Wi-Fi and Bluetooth antenna wires by gently pulling them away from the board. Disconnect the two Wi-Fi and Bluetooth antenna wires by gently pulling them away from the board.
    • Disconnect the two Wi-Fi and Bluetooth antenna wires by gently pulling them away from the board.
  8. Remove the JIS #1 screw from the WLAN card.
    • Remove the JIS #1 screw from the WLAN card.
  9. Remove the card by pulling it away from the slot.
    • Remove the card by pulling it away from the slot.
  10. Remove the four 2.9mm JIS #1 screws from each of the four corners of the fan. Remove the four 2.9mm JIS #1 screws from each of the four corners of the fan.
    • Remove the four 2.9mm JIS #1 screws from each of the four corners of the fan.
  11. Carefully grab the heat sink from any side and lift straight up while trying to avoid touching other components.
    • Carefully grab the heat sink from any side and lift straight up while trying to avoid touching other components.
    • Avoid bending the heat-pipe at all costs to keep it functional.
  12. Remove the three 2.9mm JIS #1 screws surrounding the fan.
    • Remove the three 2.9mm JIS #1 screws surrounding the fan.
  13. Carefully lift up the fan without tugging out the attached wire, and lay it on the motherboard. Use tweezers to gently unplug the power connector wire.
    • Carefully lift up the fan without tugging out the attached wire, and lay it on the motherboard.
    • Use tweezers to gently unplug the power connector wire.
    • Remove the fan from the laptop.
  14. Remove the seven screws from the motherboard using a JIS #1 screwdriver.
    • Remove the seven screws from the motherboard using a JIS #1 screwdriver.
  15. Remove the nine cables from the motherboard by carefully lifting the black tab on each connector. Remove the nine cables from the motherboard by carefully lifting the black tab on each connector.
    • Remove the nine cables from the motherboard by carefully lifting the black tab on each connector.
  16. Carefully remove the motherboard from the casing.
    • Carefully remove the motherboard from the casing.
Заключение
2 участников успешно повторили данное руководство.
Mehrab Daemi
Участник с: 22.01.2020
578 Репутация
Автор 4 руководств
Команда
York University, Team S8-G3, Turner Winter 2020 Участник York University, Team S8-G3, Turner Winter 2020
YORK-TURNER-W20S8G3
4 членов
Автор 9 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 11
За всё время: 94
