Введение
This guide will walk you through the steps to remove and replace the battery. This is a very easy fix because the battery is on the outside of the laptop and simple to remove: There are no other components blocking your access to battery. Here is a link to buy a replacement battery: Dr. Power Battery
Slide the right side switch to the left so the battery sign does not show.
Once this switch is pushed, the battery will pop out slightly and you can pull the battery out completely.
