Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
If you have a problem with the keyboard or trackpad and need to replace it, clean the dust in the system fan or gain component access this guide will show you how to remove the palmrest.
Guide notes
  • While the keyboard cable is very long, the trackpad cable is substantially shorter. Use caution when disconnecting the trackpad connector.
  • In order to disassemble this system, it needs to be disassembled top to bottom. Make sure the keyboard, trackpad and power button are disconnected before removing the palmrest.
  • This is a difficult repair. It is a good idea to have a way to sort your screws as there will be two screws to remove the palmrest. This laptop uses multiple screw lengths.
Запчасти
  1. Shut the laptop down until it is fully hibernated or powered off. Do  not remove power until both lights turn off. Shut the laptop down until it is fully hibernated or powered off. Do  not remove power until both lights turn off. Shut the laptop down until it is fully hibernated or powered off. Do  not remove power until both lights turn off.
    • Shut the laptop down until it is fully hibernated or powered off. Do not remove power until both lights turn off.
  2. Once the computer is off, remove the battery. Pull the locking tab to the unlocked position. Once the computer is off, remove the battery. Pull the locking tab to the unlocked position. Once the computer is off, remove the battery. Pull the locking tab to the unlocked position.
    • Once the computer is off, remove the battery. Pull the locking tab to the unlocked position.
  3. Remove the battery. To do this, pull the battery forward and remove it from the laptop. Remove the battery. To do this, pull the battery forward and remove it from the laptop.
    • Remove the battery. To do this, pull the battery forward and remove it from the laptop.
  4. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Remove the screw that holds the optical drive in. To do this, use a Phillips #0 screwdriver. Slide the optical drive out once the screw is removed. Remove the screw that holds the optical drive in. To do this, use a Phillips #0 screwdriver. Slide the optical drive out once the screw is removed. Remove the screw that holds the optical drive in. To do this, use a Phillips #0 screwdriver. Slide the optical drive out once the screw is removed.
    • Remove the screw that holds the optical drive in. To do this, use a Phillips #0 screwdriver. Slide the optical drive out once the screw is removed.
  6. Once the battery and optical drive are removed, remove the 11 screws that secure the palmrest.
    • Once the battery and optical drive are removed, remove the 11 screws that secure the palmrest.
    • This screw is hidden by a stick on cover. If lost, this is only cosmetic.
    • Not found on all models. On some models, there are screws in this area. If you see screws here, they must be removed.
  7. If the original pads are reused, stick them to the hinge caps. This will preserve the adhesive. Remove the hinge caps. To do this, remove the rubber pads. Use a Phillps #0 screwdriver. Remove the screws under the hinge caps. To do this, use a Phillps #0 screwdriver.
    • If the original pads are reused, stick them to the hinge caps. This will preserve the adhesive.
    • Remove the hinge caps. To do this, remove the rubber pads. Use a Phillps #0 screwdriver.
    • Remove the screws under the hinge caps. To do this, use a Phillps #0 screwdriver.
  8. The system used in the guide only came with one screw. If yours came with more then one, sort your screws accordingly.
    • The system used in the guide only came with one screw. If yours came with more then one, sort your screws accordingly.
    • With the palmrest screws removed, remove the screws under the optical drive. Use a Phillips #00 or #000 screwdriver.
  9. Do not remove the palmrest. The power button is still connected and may result in power button or motherboard damage. If you are having trouble removing the palmrest, use a guitar pick to aid disassembly. Use a plastic opening tool to remove the palmrest. Do this for all 3 sides and disconnect the keyboard and trackpad connectors. Flip the black plastic tabs on the connectors up and remove the cables.
    • Do not remove the palmrest. The power button is still connected and may result in power button or motherboard damage.
    • If you are having trouble removing the palmrest, use a guitar pick to aid disassembly.
    • Use a plastic opening tool to remove the palmrest. Do this for all 3 sides and disconnect the keyboard and trackpad connectors. Flip the black plastic tabs on the connectors up and remove the cables.
    • Once the keyboard and trackpad are disconnected, loosen the final part of the palmrest. Use a pry tool as an aid if needed.
  10. With the keyboard and trackpad disconnected, lay the palmrest out so the power button flat flex can be accessed. Disconnect it the same way as the keyboard and trackpad. Once the power button is disconnected, set the palmrest aside. Once the power button is disconnected, set the palmrest aside.
    • With the keyboard and trackpad disconnected, lay the palmrest out so the power button flat flex can be accessed. Disconnect it the same way as the keyboard and trackpad.
    • Once the power button is disconnected, set the palmrest aside.
Заключение
3 участников успешно повторили данное руководство.
Nick
Участник с: 10.11.2009
54 414 Репутация
Автор 39 руководств
Команда
Master Techs Участник Master Techs
Community
292 членов
Автор 833 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 15
За последние 30 дней: 61
За всё время: 2,522
