Введение
This replacement will not require the use of any tools. It can completed easily and in a short amount of time. You will need a clear work surface. Replacing the battery can often solve common power issues.
Выберете то, что вам нужно
Slide the battery lock latch on the left to unlock. Slide from left to right to unlock.
Slide the battery release latch on the right with continuous force from right to left.
Once battery pops, you may release latch.
Grab the battery, rotating upwards and away from you. This will remove the battery.
