Введение
In this guide, you will learn how to remove the hard drive in the HP Pavilion 15-ab165us laptop.
Выберете то, что вам нужно
Flip the computer over so that the bottom cover is facing you.
Slide the two locks to the "unlock" position and remove the battery.
Remove the two 8mm screws underneath with a Phillips #1 screwdriver.
Use a plastic opening tool to remove the plastic feet.
Remove the sixteen 8mm screws that hold the bottom cover with a Phillips #1 screwdriver.
Remove the 3mm screws that were hidden under the Optical Drive with a Phillips #0 screwdriver.
Flip the computer back over.
Use a plastic opening tool to release the clips holding the keyboard section in place.
Close the lid and pull the screen and keyboard section up and away from the disconnected bottom cover.
Locate the ribbon cable connecting the hard drive to the motherboard.
Pull the blue tab up and out from the motherboard to disconnect the ribbon cable.
4 человек успешно провели ремонт по этому руководству.
