Введение
Replacement of the motherboard for the HP Pavilion 15-ab165us.
Выберете то, что вам нужно
Flip the computer over so that the bottom cover is facing you.
Slide the two locks to the "unlock" position and remove the battery.
Remove the two 8mm screws underneath with a Phillips #1 screwdriver.
Use a plastic opening tool to remove the plastic feet.
Remove the sixteen 8mm screws that hold the bottom cover with a Phillips #1 screwdriver.
Remove the 3mm screws that were hidden under the Optical Drive with a Phillips #0 screwdriver.
Flip the computer back over.
Use a plastic opening tool to release the clips holding the keyboard section in place.
Close the lid and pull the screen and keyboard section up and away from the disconnected bottom cover.
Unlock and disconnect cables attached to the motherboard that connect to the display.
Remove the 4mm screws holding the motherboard in place with a Phillips #1 screwdriver.
Lift the motherboard up and flip it around to reveal the cable connected on the underside.
Unlock and disconnect the cable connected to the underside of the motherboard.
Pull the motherboard out of the chassis.
3 участников успешно повторили данное руководство.
