Введение
If you have noticed that your computer is no longer booting up and you have come to the conclusion that the hard drive is the problem, this guide will walk you through the sets to replace the hard drive. You will first remove the battery and then the hard drive. Using the tools suggested, you should have no problem removing the hard drive.
Выберете то, что вам нужно
Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
Carefully disconnect the cable connecting the top of the battery and remove the battery.
The hard drive is located at the lower left area of the motherboard.
Using the spudger, lift the white latch holding the hard drive cable in place.
10 участников успешно повторили данное руководство.
