Введение
If your HP pavilion 15-ay041wm laptop keyboard is not functioning properly, this guide details how to install a replacement keyboard. Ensure that the laptop is unplugged before starting this repair.
Выберете то, что вам нужно
Find the battery lock latch on the top left corner.
Slide the latch to the right position.
Find the battery release latch on the top right corner.
Slide and hold the latch towards the left to cover the battery icon.
Carefully slide the battery outwards.
Turn the laptop upside down with the base of the laptop facing you.
Remove the grippers positioned at the top right and top left of the laptop to access the two additional screws.
Use a 1.5mm Hex screwdriver to remove twelve 10mm screws.
Press the eject button.
Hold and carefully slide the disc drive out of the laptop.
Using the Jimmy, create a separation between the keyboard and bottom panel.
Slide around the body of the panel until the separation is big enough for you to use your fingers.
Separate the keyboard and bottom panel.
