Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
The LCD screen on laptops is one of the most important components as that is how the user can see and interact with the machine.
The screen might need to be replaced if it no longer produces a clear picture. If your laptop screen is cracked, dim, or producing vertical or horizontal lines, then your laptop might need a new LCD screen.
This 10-step guide will show you how to and replace the LCD screen in your HP Pavilion laptop with a Phillips #00 screwdriver.
Make sure the laptop is powered down before beginning this guide.
Запчасти
Детали не указаны.
  1. Place the laptop upside down. Place the laptop upside down.
    • Place the laptop upside down.
  2. Find the battery lock latch on the top left corner. Slide the latch to the right position.
    • Find the battery lock latch on the top left corner.
    • Slide the latch to the right position.
  3. Find the battery release latch on the top right corner. Slide and hold the latch towards the left to cover the battery icon. Carefully slide the battery outwards.
    • Find the battery release latch on the top right corner.
    • Slide and hold the latch towards the left to cover the battery icon.
    • Carefully slide the battery outwards.
  4. Place the laptop on a flat surface with the lid open.
    • Place the laptop on a flat surface with the lid open.
  5. The Essential Toolkit
    The most helpful tools in our most compact kit.
    Купить сейчас
    Купить сейчас
  6. Gently pull away the bezel by the inner edge starting from the side until bezel is detached from screen. To avoid scratching the screen, do not use any sharp objects.
    • Gently pull away the bezel by the inner edge starting from the side until bezel is detached from screen.
    • To avoid scratching the screen, do not use any sharp objects.
  7. Unsnap the two hinges attached to the clam shell by pulling towards yourself and then up. Unsnap the two hinges attached to the clam shell by pulling towards yourself and then up.
    • Unsnap the two hinges attached to the clam shell by pulling towards yourself and then up.
  8. Remove the four 3mm screws that are holding the LCD panel in place.
    • Remove the four 3mm screws that are holding the LCD panel in place.
  9. Gently pull the screen from the hooks and place it on the keyboard.
    • Gently pull the screen from the hooks and place it on the keyboard.
    • The video cable is attached to the bottom of the LCD screen.
  10. Peel the tape securing the video cable.
    • Peel the tape securing the video cable.
  11. Gently disconnect the video cable to detach the LCD screen from the back panel. Gently disconnect the video cable to detach the LCD screen from the back panel.
    • Gently disconnect the video cable to detach the LCD screen from the back panel.
Заключение
Еще один человек закончил это руководство.
Rahmatullo Khudoi Nazar
Участник с: 14.01.2020
421 Репутация
Автор 2 руководств
Команда
York University, Team S1-G2, Woodhouse Winter 2020 Участник York University, Team S1-G2, Woodhouse Winter 2020
YORK-WOODHOUSE-W20S1G2
3 членов
Автор 4 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 15
За всё время: 119
