Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
If troubleshooting steps have been followed and it is obvious that the problem with the device might be originating from a faulty battery, then follow these steps to replace your device battery. Before starting to poke into the device, ensure to take safety precautions to avoid battery fluid getting on skin or any valuables. This replacement would take about 5 minutes. So, take your time and follow the steps thoroughly and this will be a success.
  1. Power off the device and disconnect from any power source.
    • Power off the device and disconnect from any power source.
  2. Turn the device upside down and ensure the back of the device is facing you.
    • Turn the device upside down and ensure the back of the device is facing you.
  3. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  4. Push both buttons towards one another simultaneously. The battery slightly pops out. Push both buttons towards one another simultaneously. The battery slightly pops out. Push both buttons towards one another simultaneously. The battery slightly pops out.
    • Push both buttons towards one another simultaneously. The battery slightly pops out.
  5. Pull out the battery from the device's battery slot. Pull out the battery from the device's battery slot. Pull out the battery from the device's battery slot.
    • Pull out the battery from the device's battery slot.
Заключение
David Atunlute
Участник с: 30.10.2018
241 Репутация
Автор 2 руководств
Команда
UMass Dartmouth, Team S2-G2, Peak Fall 2018 Участник UMass Dartmouth, Team S2-G2, Peak Fall 2018
UMASSD-PEAK-F18S2G2
3 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 6
За всё время: 165
