Введение
This guide will show you how to replace your Memory Module in your HP Pavilion 15-b109wm. This process will take about 1 hour, and is very tedious. So take your time, complete each task carefully, and you'll have a successful replacement of your Memory Module.
Выберете то, что вам нужно
Push both buttons towards one another simultaneously. The battery slightly pops out.
Turn the device onto its side.
Using a heavy duty spudger, gently disengage the keyboard.
Tilt the keyboard to expose the Zero Insertion Force connector to which the keyboard cable is attached.
Disconnect the keyboard cable from the motherboard by detaching the Zero Insertion Force connector.
Using a JIS #1 screwdriver, remove the five 5mm screws.
Detach the power button cable.
Detach the touch pad cable.
Using a plastic opening tool, pry open the top cover.
Unscrew the two 5 mm screws using a JIS #1 screwdriver.
Gently, pull to detach the fan cable.
Using your thumbs, push out on the bracket.
When the memory module feels loose, pull up on the module.
