Введение
This guide will provide you with the steps you will need to follow in order to replace the cooling fan in your HP Pavilion 15-ba003ds.
This guide will be useful if you find that your laptop struggles to adequately cool your laptop.
Выберете то, что вам нужно
Unplug the AC adapter from the corresponding socket in the laptop.
Use your fingers to push the slider located just under the battery on either side to unlock the battery from the laptop.
Carefully slide the battery out of the laptop frame and place it somewhere safe.
