Введение
If your HP Pavilion 15-ba003ds has a screen that is damaged or will not turn on, you might need to replace it. Use this guide to disassemble and remove your old screen without damaging any other components of your laptop.
The screen itself is a thin display module that is fastened behind the frame of the upper portion of your laptop. Aside from obvious cracks, symptoms of a bad or damaged screen include the appearance of “dead” pixels, blotches, or a screen that is having trouble reaching its full brightness.
Before using this guide, check the settings on your device for brightness and contrast to see if the image cannot be corrected.
This instruction requires a steady hand and attention to technique. A mistake in this process could result in damage to the screen or wires within your HP Pavilion.
Check to make sure that you have all of the required tools and parts before beginning this guide.
Before you get started, power off the device completely and disconnect the device from any external power source.
Выберете то, что вам нужно
Apply firm pressure and slide the metal spudger along the outside edges of the front panel screen.
Flip the laptop so the bottom is facing upwards.
Using the metal spudger, separate the plastic panel off the screen.
Once the panel is separated from the screen, gently pull it off and set it aside.
Remove two 6mm Phillips #00 screws from the bottom of the screen.
Flip the screen down.
Remove the tape from over the connector.
Pull out the connector using your fingers.
