Введение
This guide is for users who need to replace the cooling fan in their HP Pavilion 15-n232nr. The tools required are the spudger, screwdriver, and tweezers.
Выберете то, что вам нужно
Slide the battery locks towards the center of the laptop. The battery will detach automatically.
Remove the battery by sliding it away from the laptop housing.
Use the iFixit opening tool to slide the optical drive away from the laptop housing.
Flip the keyboard out and locate the connector.
Use the spudger to unhinge the the fastener and remove the connector.
Release the clips securing the RAM by slightly bending them until the RAM is free.
Remove the ten 6 mm Phillips #1 screws.
Remove the three 1 mm Phillips #000 screws.
Remove the five 2.5mm Phillips #1 screws.
Use the spudger to unhinge the cable connectors. Use tweezers to complete removal.
Use the spudger to unhinge the daughterboard connector.
Remove daughterboard connector.
Use the iFixit opening tool to remove the hard drive connector.
Remove the hard drive by lifting the right side and pulling it out.
Remove the four 6 mm Phillips #1 screws.
Turn over the laptop to have easier access to the cooling fan.
Unscrew the two 4 mm Phillips #1 screws.
Disconnect the cord for the cooling fan.
Carefully lift the cooling fan from the motherboard.
Еще один человек закончил это руководство.
