Введение
If your laptop is having disc-reading errors or if the sound or video is degraded when using the CD Or DVD disc, use this guide if you need to replace your optical drive. For this guide you will need a #1 Phillips screwdriver. We will be unscrewing a screw size of 8 mm. This replacement is simple and doesn't require extensive knowledge.
Выберете то, что вам нужно
Flip over the laptop so that the screws on the bottom are exposed.
Use a #1 Phillips screwdriver to remove the single 8 mm screw that secures the optical drive.
