Введение
The hard drive may malfunction if physically damaged or put under a lot of stress. Use this guide to replace it if the computer won't boot and or is displaying errors.
Выберете то, что вам нужно
Pull the battery out towards you while your fingers are still holding the latches in place.
Remove the thin plastic cover using the flat metal spudger to expose another screw.
Remove one 7 mm screw with a Phillips #0 screwdriver.
Underneath each rubber foot, there is a screw.
Use the Phillips #1 screwdriver to remove a 4.8 mm screw on each side.
Remove the following six screws with a Phillips #1 screwdriver:
Two 7 mm screws.
Two 7 mm screws.
Two 4.8 mm screws.
Remove two 2.4 mm broadhead screws from the CD Drive bay with a Phillips #0 screwdriver.
Flip the laptop back over. Then, with the laptop open, move the plastic prying tool around the top cover to pry it from the enclosure.
Remove the ribbon connecting the keyboard to the motherboard.
You may now fully lift the front panel from the rest of the laptop.
Lift the black retaining bar that holds down the two hard drive ribbons to unlock them.
8 участников успешно повторили данное руководство.
Один комментарий
Thank you. Couldn’t figure out why those end caps wouldn’t budge. Dang hidden screws! Kudos!
