Введение
Please follow this guide only if you are having trouble with a few keys. If numerous keys aren't working, you may have to replace the entire keyboard.
Выберете то, что вам нужно
Carefully remove the key by prying at least two sides up with the plastic removal tool.
Remove two square black pieces from the area under the key with a pair of tweezers.
Remove a small square piece first.
Remove a larger square piece next.
Once the key is removed, use a clean cloth or cotton swab to remove any particles.
7 участников успешно повторили данное руководство.
2 Комментариев
How do I put the keys back in? I need help please. Thanks
this should work https://www.youtube.com/watch?v=vSdLluMY...
