Введение
This guide outlines how to remove and replace your device's screen. Please follow this guide only if your original screen is beyond repair and replacement is absolutely necessary.
Выберете то, что вам нужно
Pull the battery out towards you while your fingers are still holding the latches in place.
Remove the thin plastic cover using the flat metal spudger to expose another screw.
Remove one 7 mm screw with a Phillips #0 screwdriver.
Underneath each rubber foot, there is a screw.
Use the Phillips #1 screwdriver to remove a 4.8 mm screw on each side.
Remove the following six screws with a Phillips #1 screwdriver:
Two 7 mm screws.
Two 7 mm screws.
Two 4.8 mm screws.
Remove two 2.4 mm broadhead screws from the CD Drive bay with a Phillips #0 screwdriver.
Flip the laptop back over. Then, with the laptop open, move the plastic prying tool around the top cover to pry it from the enclosure.
Remove the ribbon connecting the keyboard to the motherboard.
You may now fully lift the front panel from the rest of the laptop.
There is a metal component connecting the screen to the casing underneath each hinge.
Remove three 5.6 mm screws with a Phillips 1 screwdriver on each side.
Lift the black retaining flap to remove the black cable connecting the screen to the motherboard.
Locate the thin black wire that trails from the screen and remove it from the motherboard.
Remove two small rubber covers on the bottom right and left edges of the screen enclosure using a metal spudger to expose two screws.
Remove one 5.6mm screw with a Phillips 1 screwdriver from each side of the bottom screen.
Use a metal spudger to remove the plastic casing from the perimeter of the screen.
Еще один человек закончил это руководство.
