Введение
The HP Pavilion 17-f127ds, is a standard “QWERTY” keyboard, if there is a malfunction or if you need to use a different language keyboard, you will need to remove the keyboard manually, this guide will assist you in the matter.
Выберете то, что вам нужно
Slide the battery lock latch, the latch on the left, inwards.
Slide the battery release latch on the right inwards to release the battery.
Lift the battery up and remove it from computer.
Flip your laptop over on a firm surface.
Using a Phillips #1 screwdriver, remove the thirteen screws on the back of your laptop.
Flip your laptop back over.
Using the opening tools, separate the keyboard from the laptop by prying it from the base along the sides of the laptop.
With your fingers, disconnect the keyboard connector and the connector cable from the motherboard.
Carefully remove the keyboard.
2 участников успешно повторили данное руководство.
