Введение
This guide will teach you how to remove the back cover of the laptop. This guide will be important for a lot of other replacement guides.
Выберете то, что вам нужно
Remove the fifteen 7mm screws holding the back casing on using the Phillips #00 screwdriver.
Remove the 7mm screw holding the disc drive in place using the Phillips #00 head screwdriver.
Remove the four 7mm screws holding the back resting plates on using the Phillips #00 screwdriver.
Using a metal spudger, lift up on the back resting plate until it pops off.
Pry up on the case with an iFixit opening tool until you can feel a snap.
Pry around the remainder until you can separate the case from the keyboard with your hands.
Gently separate the two.
3 участников успешно повторили данное руководство.
