Введение
If your HP Pavilion DM3-3010US screen display is showing limited or no visibility, you may have a broken screen and will need it replaced. This guide will take you step-by-step in replacing your laptop screen.
Выберете то, что вам нужно
Place the laptop upside down on a stable surface and locate the battery ejection switch.
The rectangular panel can be removed by sliding the latch.
The square panel is removable once the battery is removed.
Locate the two screws located on the side of the hard drive mounting hardware.
This is accessible from the back of the laptop, where the battery was located.
Locate the 4 additional screws on the top of the mounting hardware for the hard drive.
Remove and set aside these screws.
With the hard drive removed, open the laptop and set it down in the position for normal use.
Locate the seam between the top panel of the laptop and the frame.
Pull the top cover, including keyboard, up from the left side of the laptop.
Release the hinges by removing the three Phillips PM2.5x7.0 screws and hinge covers that secure it to the base.
Remove the two rubber screw covers and the two Phillips PM2.0×4.0 screws at the bottom of the enclosure. This will give you access to the internal components.
To detach the display bezel, flex the inside edges on the top, bottom, left, and right sides until it is fully detached. Then, lift it away from the rest of the screen enclosure.
Next, remove the four Phillips 2.0×3.0 screws at each corner that secure the display panel to the enclosure. Then, you can remove the hinges on each side.
Remove the display panel cable by releasing the adhesive strip. Then, you can safely disconnect the display panel cable from its port.
You can also view this maintenance and service guide provided by HP here: http://h10032.www1.hp.com/ctg/Manual/c02...
Еще один человек закончил это руководство.
