Выберете то, что вам нужно
Shut down the computer.
Disconnect all external devices and cables from the computer.
Locate the gray sliding tab next to the black bar where the battery is located.
Slide the gray sliding tab to the left until you hear a distinct click.
The inside edge of the battery should pop up.
Grasp the inside edge of the battery.
Lift the inside edge of the battery up to detach the battery from the laptop.
Remove the highlighted screws.
After removing the screws, flip the laptop over.
Open the laptop.
Use the spudger to lift the keyboard.
Press the two white clips forward with your fingers and gently pull the ribbon from the clips.
Turn the laptop right-side up. Open the screen and tilt it all the way back.
Locate the media keys.
Gently lift up the media key strip using the plastic pry tool.
Remove the rubber inserts with the spudger.
Remove the screws behind the rubber inserts.
Remove the screws on each side of the screen. There are four screws on each side.
Remove the screen.
3 участников успешно повторили данное руководство.
