Введение
The Hard Drive this computer comes with has 120GB of space and runs at 5400 RPM. Accessing the Hard Drive is simple and requires removing a total of only 4 screws.
Выберете то, что вам нужно
Start with the bottom of the laptop facing up.
Locate the panel covering the hard drive compartment.
Unscrew the two 5mm Phillips #0 screws.
Locate the second plastic panel covering the hard drive.
Unscrew the two 4mm Phillips #0 screws holding it in.
Grab the end of the hard drive and pull it up to a vertical position.
Gently slide the Hard Drive off of the SATA connector.
Еще один человек закончил это руководство.
