Введение
The Wi-Fi adapter is a crucial piece of hardware in your laptop, allowing access to the Internet via Wi-Fi connection. If you're having problems with connecting to the Wi-Fi, the wifi adapter could be the reason, so you could use this guide to remove and repair or replace the Wi-Fi adapter.
Выберете то, что вам нужно
Start with the bottom of the laptop facing up.
Locate the small panel under the battery, which houses the wifi adapter, and unscrew the one 5mm Phillips #0 screw holding the panel in place.
Remove the panel and set it aside.
Unscrew the two 3mm Phillips #0 screw which is located at the corners of the wifi adapter.
Pull the 2 black wires with the gold pieces out of the wifi adapter.
The wifi adapter is now free to be removed.
Еще один человек закончил это руководство.
