Введение
This guide outlines how to replace the hard drive. Replacing the hard drive is a simple process, and this guide describes that process. While there may not be pictures, there is a high quality step-by-step guide all focused on replacing your hard drive.
Flip the computer so that the bottom side is facing up, and locate the battery above the screen hinges.
Unscrew the two silver screws holding the protective cover in place.
Remove Cover by lifting the edge along the battery compartment.
Slide the hard drive towards the empty gap, lift up on the hard drive, and remove it.
