Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
This guide aims to walk users through the process of replacing the optical drive on their HP Pavilion G6-1d16dx. There are 3 easy steps; each step has pictures to aid users trying to do this repair.
Запчасти
Детали не указаны.
  1. Unscrew screws holding the protective cover in place until they make a clicking noise. Screws do not detach from protective cover.
    • Unscrew screws holding the protective cover in place until they make a clicking noise.
    • Screws do not detach from protective cover.
    • Unsnap the cover by lifting the edge along the battery compartment.
  2. Use a PH0 screwdriver to remove the single screw holding in the optical drive.
    • Use a PH0 screwdriver to remove the single screw holding in the optical drive.
  3. Slide out the optical drive.
    • Slide out the optical drive.
Заключение
Calvin Kerr
Участник с: 05.04.2018
837 Репутация
Автор 5 руководств
Команда
Linn Benton Community College, Team S2-G6, Johnson Spring 2018 Участник Linn Benton Community College, Team S2-G6, Johnson Spring 2018
LBCC-JOHNSON-S18S2G6
4 членов
Автор 8 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 87
