Введение
If your Wi-Fi is not working for whatever reason and you need to replace the wireless card, you've come to the right place. This guide outlines the process of replacing the wireless card, which is responsible for Wi-Fi connection. Between the clear steps and pictures, your computer should be connected to the internet in no time.
Выберете то, что вам нужно
Flip the computer so that the bottom side is facing up, and locate the battery above the screen hinges.
Unscrew the two captive screws using the Phillips #000 screwdriver.
Unsnap the protective cover off of the device.
Locate the wireless card.
Remove the two screws located on the corners of the wireless card, using the Phillips #000 screwdriver.
Slide the Wi-Fi card out of the socket.
Еще один человек закончил это руководство.
