Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide will show you how to replace the screen of the HP Pavilion G60-247CL.
Выберете то, что вам нужно
Press down and to the right on the battery lock slide.
Once slid over to the right the battery will pop up and out.
Remove the seven screws from the back side of the laptop using a Philips Head screwdriver size PH1.
Remove the seven screws from the battery compartment using a Philips Head screw driver size 0.
Turn the computer around to the front side.
Using the spudger tool prop open the key board casing.
Carefully lift up the key board.
Then gently pull up the connecting wire clip to completely detach the keyboard.
At the top right of the laptop there will be an another wire clip holding the keyboard casing.
Carefully pull out the wire clip to fully detach the covering.
At the top right of the laptop remove the black wire from under the metal tabs using the tweezers.
At the top left of the computer remove the black clip using the spudger.
Push the spudger to the right to pop out the clip.
Locate at the bottom left of the computer a white clip.
Using the spudger prop out the white clip.
On the left side of the computer locate the black wire with the clear clip.
Gently pull the wire to the right to detach it.
At the top corners of the computer, unscrew the 3 screws using a Philips Head screwdriver size 0.
Lift up the top half of the computer carefully.
Locate the two screws at the bottom corners of the screen.
Using the tweezers remove the rubber black covering over the screw.
Using a Philips Head screwdriver size 0 remove the two screws.
Using the spudger prop off the screen covering.
Remove the covering to expose the screen completely.
Remove the bottom two screen bearings.
Using a Philips 1 screwdriver remove the two screws on each side.
Using the tweezers remove the red and white wire from the bottom of the screen.
While the screen is still propped open remove the black wire from the bottom middle of the screen by pulling gently.
