Введение
For the RAM replacement of your laptop, you will need a screwdriver and a couple other tools. This is a relatively easy replacement and should take no more than five minutes.
Выберете то, что вам нужно
Slide the battery release switch to the center of the computer to release the battery.
Loosen the 7.25mm screw on the bottom of the laptop holding the "L" shaped cover down.
Using either your fingers or two metal tools, push outwards on the two prongs until the RAM card pops out.
Еще один человек закончил это руководство.
