Введение
This guide provides instruction on how to replace a broken optical drive in the HP Pavilion G7-2289wm laptop.
Выберете то, что вам нужно
Located on the bottom side of your laptop, slide the battery release latch to the left, towards the center of the laptop.
Lift the battery up, and pull towards the center of the laptop to remove it.
Loosen the screw that secures the service cover using a Phillips #0 screwdriver.
Lift the edge of the service cover up and forward until it’s at an angle to remove it.
Remove the screw that secures the optical drive to the laptop using a Phillips #0 screwdriver.
Slide the optical drive out of the laptop.
