Введение
This guide provides instruction on how to replace a broken or damaged touch pad on the HP Pavilion G7-2289wm laptop.
Выберете то, что вам нужно
Located on the bottom side of your laptop, slide the battery release latch to the left, towards the center of the laptop.
Lift the battery up, and pull towards the center of the laptop to remove it.
Loosen the screw that secures the service cover using a Phillips #0 screwdriver.
Pull the edge of the service cover toward you to remove it.
Remove all the screw that secures the keyboard to the computer using a Phillips #0 screwdriver.
Flip your laptop around to the front, using an opening tool, pry around the perimeter of the keyboard.
Lift the keyboard from the top backward towards the touch pad.
Unlatch the keyboard connector from the motherboard and remove the keyboard.
