Введение
If the laptop is overheating, it is possible that your fan is malfunctioning or needs to be cleaned. To replace, a replacement must be purchased and installed, while cleaning does not require a new fan. Follow this guide to clean or replace your computer fan.
Выберете то, что вам нужно
Using a Phillips #1 screwdriver, remove the 4.5 mm screw securing the fan cover to the device.
Lift the fan up from the device.
Disconnect the fan cable to fully remove the fan from the device.
Еще один человек закончил это руководство.
