Введение
If the hard drive in your system failed or you want a larger hard drive (or are upgrading to an SSD), this guide will show you how to access the hard drive for replacement.
==Guide notes==
- Replacement of the hard drive requires partial disassembly. If you are unsure if you can do the job, have someone who knows how to do it work on it for you.
- Test the computer before reassembly by only assembling it enough to test for power. If something doesn't work, you will need to tear the whole computer down a second time if you did a complete reassembly.
Выберете то, что вам нужно
Slide the finger latch to the left to release the clip holding the battery into the laptop.
While continuing to hold the finger latch, slowly lift up on the tab to remove the battery from the device.
Once the button is unlocked to the side, slide the hard drive enclosure away from the device.
The hard drive will be clipped into the underside of the hard drive enclosure and can be removed for replacement.
Еще один человек закончил это руководство.
