Введение
This guide will walk you through the steps required to remove and replace the keyboard of the HP Pavilion Sleekbook 14-b013cl.
Выберете то, что вам нужно
Flip the computer over and move the battery lock switch to the "unlocked" position (marked by an orange lock icon).
Press the switch on the right-hand side of the back of the device towards the center until the gray battery icon is no longer visible. This will eject the battery.
Use a plastic opening tool to pry up one of the upper counters on the keyboard
Run the tool along the upper edge of the keyboard and towards the opposite corner to release the latches.
Push the button to release the connector and pull it out and remove the keyboard
Еще один человек закончил это руководство.
